I need a manual for the Powermate 5000 generator.
Go to www.colemanpowermate.com, click on portable generators,click on manuals at top of page.
you will need to know the exact model #, look on black plastic cover on the back of the generator.
SOURCE: What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
SOURCE: Powermate 5000
20kw means 20 KILOwatts (kilo=1000), so 20kw=20,000 watts
So the Powermate 5000 refers to wattage. 5000=5kw
SOURCE: Need to know about this
To find a manual for this generator go to powermate.com and search your model and serial number. Good luck!
SOURCE: I need a manual for the coleman powermate 5000
http://www.powermate.com/productmanuals.php?cat_id=3
If you have the model # you can get it from this link.
SOURCE: Coleman Powermate Maxa5000 ER Plus Generator
Unfortunately, a service manual is not going to be easy to find. You may be able to order from Powermate, but you may want to save your money and spend it on consumables.
I am guessing that you are looking for a service manual for the engine itself? Good Luck on that one as well, as Tecumseh has folded. Post the engine model# and other information found on the tag, somebody (perhaps myself) may have the manual you need and send it to you via email.
Parts for the engine itself are likely to be hard to find, consider an engine replacement. It likely will be cheaper.
