SOURCE: Nikon Coolpix S51 - unable to install software on Window ME
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
SOURCE: computer can't detect my digital
check the all ports USB with other thing , conect and chek if it works, if all is ok , then install the cd camera and after conect the camera again
SOURCE: I can't find any drivers for window 7 for a Nikon
Kindly get it downloaded at :
www.nikonusa.com/Service.../index.page
www.opendrivers.com/.../nikon-free-driver-download.html
www.driverskit.com/.../Camera/Nikon/Digital_Camera/18483.html
Kind regards
SOURCE: When I connect my Nikon Coolpix 8700 to my Windows
Having gone a month without a response, I assume using a card reader solved the problem.
SOURCE: how to transfer pictures from nikon coolpix L25 to computer which is taken without using scandisk
Insert the memory card, press the MENU button, select the Playback menu (right-pointing triangle), then select the Copy command.
