Question about Maytag MDE9700AYW Neptune 174 Electric Dryer
Dryer won't work-looks like no power
I turned on my dryer today & it started working like normal but several minutes later I went in & it had stopped. There are no lights on and appears to not be getting any power. I have checked all breakers & unplugged it without any luck. Any other ideas of how to fix it?
  • Maytag Master
  • 3,462 Answers
Gain access to the inside and the wiring of the machine.
First, check the wires with a meter and see if electricity is even getting to the 3 or 4 wire "buss bar" where the electric cord attaches from the wall to inside the machine.
If all that tests OK, then take an ohm-meter or a multi-meter and begin testing each of the "fire-protection" circuits.
You may find as many as 6 thermal switches, and as many as 3 fuses.
Unplug each one you test, and test it with the ohm-meter for continuity.
The one that shows no continuity is your problem.
God bless your efforts.
Posted on Feb 22, 2018
    Genius:
  • 1,728 Answers
Might be thermal fuse.
6ya staff
SOURCE:
robert samples
  • 1314 Answers
SOURCE: Dryer starts then stops after a few seconds.
thank you ill get back to you after reading the tech manual shortly
Posted on Jan 17, 2008
localwonder
Michael Masters
  • 6784 Answers
SOURCE: NO POWER TO DRYER???
Hi there, you are experiencing a power supply board failure. this board may have used all its life up and unfortunately, it will have to be rebuilt or replaced.
Posted on Feb 05, 2009
Anonymous
  • 70 Answers
SOURCE: no power to maytag duet
most maytag "performa" dryers with no power h appen froma blown thermal fuse. It is located under the top and beside the heating element. you can take an ohm meter to both terminals.If you do not get a reading, the part is bad. It comes as a kit with a new safety tstat
Posted on Feb 19, 2009
Anonymous
SOURCE: Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Posted on Mar 08, 2009
bozcro
bozcro
  • 867 Answers
SOURCE: Hello, today our dryer won't run. The control
if nothing works,belt may be broken, cutting of power via safety switch. check belt
Posted on Aug 08, 2009
I have a bran new Admiral dyer that won't work
The dryer may have been wired incorrectly, e.g., 115v rather than 230v.
May 23, 2017 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Traction disabled, car wont start
Your battery is no good - replace it.
Sep 14, 2017 | 1994 Cadillac Seville
Car was rinning perfect. One day it would not start. there was nothing, no clicking ,bell and guages were working. Jump start was nothing. Installed a new battery there was nothing. Went bact back 2 hours...
It sounds like you have an issue with your PassLock security system. I had the same with my 2002 Impala. Key turns OK, but won't start, won't crank. Wait 20-30 minutes, and car starts normally. There is usually a clue from the Battery and Security lights.
The problem starting to happen once a month, and eventually 1-2 times a week.
There are several write-ups on this problem for several GM cars for 2000-2006(?). Search this website, and search the web.
The official solution is to replace the ignition switch. The best solution is to bypass the Pass Lock system. I went ahead and did a full bypass, which involves cutting wires and adding resistors to the ignition circuit. I have not had a problem since.
Aug 19, 2011 | 2004 Chevrolet Impala
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Sep 12, 2009 | Maytag Dryers
Car won' start
Sounds like baD FUEL TO ME.
Jul 29, 2008 | 2002 Pontiac Grand Am
Maytag MDE9700AYW Neptune 174 Electric Dryer Logo
143 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
