This hard reset can be done even if the device won't seem to power on.
SOURCE: i just bought a samsung
Hi!
First of all in user's guide manual says that this tablet works just fine with only 3 IM : 1.Google Talk; 2. Windows Live Messanger 3. Yahoo! Messanger.
Try one of those to see if the camera button appears.
However, if you need more information you can find them here: ( http://www.userguidemanual.com/samsung-galaxy-tab-gt-p1000-tablet-manual-user-guide-french-english/ ).
*This link allouds you to read and download free user's guide manual (in PDF format).
I hope this will work!
Have a nice day!
SOURCE: My samsung galaxy tablet is
It appears your Galaxy is faulty and it will still be under warranty. I suggest you take it to the supplier to get it repaired or replaced under warranty.
If you try to repair it yourself, you will most likely void your warranty.
SOURCE: Hi, i m not able to find the motion sensor
its in notification panel by the name orientation lock.
SOURCE: can I reset my Galaxy Tablet 10.1?
I think you'd better ask Samsung for tech help, if you mean reinstall the OS, I think you can.
Android 4.0 Tablet PC
Note: These steps clear data from the device. SD card data like your photos and music are not erased unless you choose to format the SD card.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Upuntil the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. PressHome to choose the selection.
4. Press Volume Up continue.
The Galaxy Tab should then go through the hard reset process.
If you have access to the OS, you can also perform a hard reset in Settings.
1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
1. With the device off, press and hold Volume Up and Power.
2. Select Privacy.
