SOURCE: 2001 Dodge Stratus Transmission Problem
COULD BE LOSS OF ALL TRASMISSION FLUID, BROKEN HOSE, BLOWN PUMP,BURNT TRANSMISSION RINGS( HOW DID THE TRANNY OIL SMELL?) BURNT TRANNY FLUID OR A COMBINATION OF ANY OF THE ABOVE. IF IT JUST QUIT, YOU PROBABLY HAVE A SERIOUS PROBLEM THAT WILL REQUIRE A REBUILD OR A SALVAGE TRANSMISSION FROM A LOCAL WRECKING YARD. THE LATTER BEING THE CHEAPEST AND AT TIMES THE BETTER DEAL ALL AROUND, TIME WISE AND MONEY. VERSUS A REBUILD THAT REQUIRES NEW PARTS, BANDS, PUMP, SEALS AND ON AND ON PLUS HOURS OF LABOR TO FIX EQUALS ONE BIG BIG BILL!BEING A 2001 A TRANNY FROM A WRECKING YARD ISN'T GOING TO HAVE THAT MANY MILES ON IT EITHER SO YOU SHOULD BE ABLE TO FIND SOME PRETTY DECENT ONES. THAT'S THE ROUTE I'D GO, BUT YOU'RE FREE TO CHOOSE EITHER CHOICE. I DON'T ENDORSE OR CONDEMN EITHER ONE, JUST POINT OUT THE GOOG AND THE WEAK IN EACH FOR YOU TO DECIDE! GOOD LUCK! IF I CAN HELP REPLY TO: ARCLIGHT1217
SOURCE: dodge stratus rt fuel filter location
were is fuel filter st on a dodge stratus 2001 4dr 2.4L DOHC
SOURCE: 2005 DODGE STRATUS HOW TO REPLACE THE BATTERY
REMOVAL
The battery is accessible without removing the left front wheel and tire assembly..
Verify that the ignition switch and all accessories are OFF.
Turn the steering wheel to the full left position.
Disconnect and isolate the negative battery cable remote terminal from the remote battery post.
WARNING: NEVER GET UNDER A LIFTED VEHICLE IF NOT SUPPORTED PROPERLY ON SAFETY STANDS.
Remove battery splash shield. Refer to the Body section of the service manual for the procedure.
Disconnect the heater blanket cord, if equipped.
Remove the short bolt from the battery hold down and remove the hold down (Battery Location).
Disconnect the negative and positive battery cables from the battery.
Slide the battery toward rear of vehicle and lift out of the battery tray.
Remove battery from vehicle.
ok first of all any fuel ran motor has a fuel filter on it somewere. on the r/t you pull up your back seat and remove your fuel pump modual it is on the bottom of the model
If its a 2001+ Stratus Coupe first you need to remove the 2 bolts on the left and right sides of the lower middle dash assembly, these are at the very bottom of the assembly close to the center consuel (were your gearshift knob is. Once you remove those the assembly around your stero will come off. After that its just a matter of unbolting the stereo, sliding it out and removing the wireing harness in the back.
hope this helps
