SOURCE: I have a GE washer
Hello, This unit does have a belt. Since you hear the motor running but its not spinning i would check the belt the part # is WH1X2026. to check it there are two clips in the top front corners in the gap between the top and front panel you cant see them you slide a putty knife in the gap and pop the clips in and slide the front panel down then you will have access to the belt. It drains because it has a electric pump not controlled by the belt.. Hope this helps..Please dont forget to rate me :)
