SOURCE: new handgrips on 2008 road king
check any service manual, they are all about the same system. I think I know what you are saying though.Take the switch housing off the right side, twist the throttle one way then the other to dis connect cables( there is 2). Old grip should slip right off. Is ther manual cruise on it? If so, that will need to be dis assembled as well (in the switch housing) It is not easy to do if you have big mitts.
SOURCE: My 2008 road king has an annoying whine when I
Your transmission has a straight cut 5th gear and not a helical cut 5th gear.
HD fixed this whine with the 2010 touring models.
SOURCE: i need a wiring diagram for a 2000 road king can
its in the back of your Repair manual that im sure you bought right?
SOURCE: 2002 road king horn wiring were due both leads connect to
I am assuming you mean what are the color of the wires that go to the horn. If so, the yellow/black is positive when the horn button is depressed and the black is ground. The wiring for the horn button is orange/white positive and yellow/black to horn. The orange/white wire gets 12vdc from the acc fuse.
SOURCE: How many ounces does a 2008 FLHR Harley Davidson Road King hold?
Well i blow about 20 ounces of fluid and u ?
I guess you are talking about fork oil? it's measured!!!
