Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
Viewsonic N2750W has menu screen constantly flashing on and off.
I have tried several reset button combinations I have found on here. without any success. If i press the power button and the enter button at the same time the tv comes on but only cycles through colors. To turn it off i need to push the power button and enter again. If i only press the stand by button it doesn't do anything. I have tryed the OCD lock it comes on and off by pressing the channel down arrow for 10 seconds The power button lock also works by pressing the up arrow for 10 seconds. I have tried holding several combinations of buttons as i switch the power switch in the back without any success either. If I hold the power button down it will stop cycling the menu screen and I can use the remote to navigate the menu. I did a channel search and then the TV started working normally again, but it was short lived. Anyone have any ideas on what to try next?
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 271 Answers
SOURCE: viewsonic n2750w 27" turn on the tv it gets 4 different colors
if you have a reset button (might be hidden)...hit dat
Posted on Dec 17, 2008
Anonymous
SOURCE: Viewsonic N2751w continues to cycle thru channels at startup
Unplugged the TV and removed and reinstalled each connection. Don't know why but it was enough to resolve the issue.
Posted on Jan 06, 2009
HOW TO UNLOCK A PANTECH PHONE WITH TO MANY PATTERN ATTEMS
1. try entering null as password. (together with your google username) 2. try entering your username without @gmail.com
3. Combine 1 and 2
4. Call yourself from another phone, answer, without hanging up press the home button, then menu button, settings, try to disable pattern-lock 5. Call yourself from another phone, answer, hang-up, directly after hanging up start pressing your buttons like a madman for <30-60 seconds ending with your home button (might take a while to get the timing right). Go into settings and disable pattern-lock.
6. go to recovery (vol down + search +power) and do a factory reset/wipe (it will erase all your files)
Feb 18, 2014 | Pantech Great At&t P9070 Burst Smartphone
How do i unlock my pattern lock on my galaxy s2
1. try entering null as password.2. try entering your username without @gmail.com3. Combine 1 and 24. Call yourself from another phone, answer, without hanging up press the home button, then menu button, settings, try to disable pattern-lock5. Call yourself from another phone, answer, hang-up, directly after hanging up start pressing your buttons like a madman for <30-60 seconds ending with your home button (might take a while to get the timing right). Go into settings and disable pattern-lock.6. Try the normal recover password routine from GMail.com
7. Perform a factory reset. YOU WILL LOOSE all not-synced DATA (SD card will be left untouched).
1-6 are possible workarounds, these doesn't work for everyone but can be worth a try to avoid factory reset. 6. is what should work but hardly never does. 7 - The factory reset always work
Added reference with some additional info, how to factory reset can be found there.Good luck!
Oct 14, 2011 | Samsung Galaxy S GTI9000 Smartphone
Samsung R4266w turns off automatically. I've
Rest the lamp hour meter
  • 1 Press menu on the DLP's remote.
  • 2 Scroll down the list to "Timer."
  • 3 Press "Enter" on the remote, then "Reset." Press "OK" to complete the process, and "MENU" to exit the menu.
Service Level Reset
  • 1 Turn off the DLP with the remote.
  • 2 Press a pre-determined button sequence on the remote control to access the factory reset option. These sequences are found in the owner's manuals of the various DLP televisions, or in the "Support" sections of the manufacturers' websites. Scroll to the "RESET" option on the menu to reset the bulb timer.
  • 3 Press a factory-determined combination of buttons on the remote and front panel of the individual DLP display to reset the bulb timer without entering a menu.
Aug 14, 2011 | Samsung Televison & Video
I have a main Password set on the labtop and i cant reset it without the password. How can i reset it?
Dear Friend,
If you are referring to the Bios Password, removed the battery and push down the power button for about 30 to 60 seconds to reset it (this apply to major brands). If it does not work, you might have to open apart and removed the bios battery for about 5 seconds.
Now, if you are referring to the Windows Password, there are many software that can help you to achieved this (Google it). Normally, in Windows XP you press down the following key combination: Crtl + Alt and press the Del button twice (during log on screen) this will bring the Log on to Windows screen where Username can be try as Administrator with no password, allowing you to get inside and change your password.
Good Luck!!!
Feb 20, 2011 | Compaq Presario R3000 Notebook
I have reset the WNDR3300 and used the disc to try to get a new password; however, a window keeps popping-up that wants my username and password. I tried every conceivable combination without any success....
Please try to reset the router with the reset button atleast 30 seconds depressed... And again unplug the power cable and plug the power cable by pressing the reset button n leave it after 30 secs..
and then again unplug the adapter cable n plug in n have the fun...
Thanks
Sep 20, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
The display is not appearing. I can hear it come
The Garmin fitness models are unreliable. Problems like this are common. The Motion Based forum will provide help. If a hard reset does not work you'll have to phone Garmin. I found this post regarding the Hard Reset:
"With the unit powered off hold down mode, continue to hold down mode while pressing power. Then let go of both buttons. You will be asked "Do you really want to erase all user data?" Select yes
If that doesn't work there is another "unprompted" hard reset that will clear all data immediately without asking. It's not easy to do, so you might have to try it several times before it works.
Hold down enter and mode while pressing power (don't hold down the power button, just press it quickly) Keep holding down enter and mode for a few more seconds. You will then see the "select language" screen and the rest of the initial setup screens."
Nov 04, 2009 | Garmin Forerunner 305 GPS Receiver
How to change tax rate on Casio MS120TV
I found the solution listed against a different CAsio Calculator.
It was .. Press AC, then hold 'set' for a few seconds then press 'Tax+' , input new tax rate then press 'set'. Job Done
Jan 06, 2009 | Casio FR-2650Plus Calculator
Rings as long as power cord is plugged in
The problem is that your phone now has the same intercom number as one of the other phones you have connected to your system.
Press PROGRAM
Press *
Press #
Enter 2 digits (11 through 22)
Press Intercom. After a successful assignment you will hear a confirming ring.
May 27, 2008 | AT&T 954 Corded Phone
Forgotton password for Sharp OZ-730
Hi, I has this problem but I found in the user manual this instructions and works ok: 1. Press and hold the Start key.
2. While holding down the Start key, push the RESET button
on the bottom of the Organizer using a pen or some other
pointed object. The following message will appear.
"Do you really want to initialize the organizer's memory (this will delete all data)? Yes:[ENTER/No:[ESC]
3. Press to initialize the Organizer.
The message .Working... Please wait.. appears while the
Organizer proceeds with the initialization procedure.
The Welcome message then appears.
Jan 04, 2008 | Sharp Wizard OZ-730
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
176 people viewed this question
Top ViewSonic Televison & Video Experts
lubomir73
Level 1 Expert
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
