Question about KitchenAid New Professional 5.5 QT Commercial Style Wide Steel Bowl Stand Mixer 550 HD 575 Watt Motor- Empire Red
When i raise the bowl to mix, the paddle will not make good contact with the bowl to scrape the bowl and so I can not work the dough correctly. I have added "washers" to the little hooks where the bowl sits and this is still not good. Can I adjust the bowl to sit higher? If so how?
You can adjust the mixer bowl up and down slightly. If you lower your bowl and look at the back you will see a little screw, it looks like a flat head screw and it is on the "neck" of the mixer.
You can raise and lower the bowl by adjusting this cam screw. You can tell that your bowl is adjust correctly by attaching the flat beater and put a dime in the bottom of the bowl, the beater should just barely touch the dime and move it around the bottom of the bowl.
The beater will not scrape the sides of the bowl, if you are wanting the sides of the bowl scraped I would recommend the Flex Edge Beater made by KitchenAid which is basically a flat beater with a rubberized edge which will scrape the side of the bowl as it rotates.
Here is a link to the flex edge beater on our website: http://www.mendingshed.com/kfe6l.html
Let me know if you have any other questions.
Thank you,
ColleenCustomer ServiceMendingShed.com800-339-9297
Posted on Apr 12, 2013
SOURCE: KitchenAid 600, Stand Mixer -
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Posted on Feb 13, 2009
SOURCE: Paddle Scraping - KitchenAid Professional 600
There is an adjustment screw and a system for setting it. You can find a video of it here (or just a ton of people who know all about these mixers). I just found it while trying to troubleshoot the same problem for my wifes mixer.
http://forum.kitchenaid.com/forums/forum.asp?FORUM_ID=196
Posted on Nov 02, 2007
SOURCE: KitchenAid 575 Professional Mixer
Read the instruction manual. There is a screw to adjust the beater height, it is where the mixer joins to the stand.
Posted on Mar 25, 2008
SOURCE: Dough blade is scraping the
If you're still having this problem, here's what I did a few minutes ago that fixed it. Lift the head, then turn the screw that connects the head to the base to the left. You're basically unscrewing it. That screw regulates how high or low the beater is. Unscrew it a little at a time, and lower the head and try to lock after each turn. The head will gradually get in a more locked position. Keep turning the screw till the head finally locks in all the way. Read the "beater to bowl clearance" section in the manual.
Posted on Dec 10, 2010
Dec 29, 2014 | KitchenAid Kitcheaid 5 Qt. Artisan Stand...
Dec 14, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Nov 12, 2017 | KitchenAid KSM150PS Artisan Series Stand...
Jan 02, 2018 | KitchenAid K45SS Classic Stand Mixer
May 21, 2010 | KitchenAid RKG25H0XWH Mixer
May 01, 2010 | KitchenAid KP2671 Professional 6 Series...
Apr 17, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Jan 03, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Dec 21, 2008 | KitchenAid K45SS Classic Stand Mixer
Jan 31, 2007 | Bosch 700 Watts MUM7010 Concept Series...
183 people viewed this question
