Pull out the spark plug and plug it into the spark plug lead. Connect a jumper wire between a cooling fin and the threaded part of the spark plug. Pull the starter cord and watch for the spark to jump the gap. It should be bright blue. Do this in dim light. If you see no spark you have an ignition problem.
Not to sure without seeing or hearing it being pulled over. Compression? Very likely needs some carb work/kit.
Remove muffler and clean thoroughly.
