I went for a run on the treadmill today. The heart rate monitor was off from the start. It showed my bpm was 156 and I just started walking - should have been in the 90 range. At one point it got up to 200bpm - I wasn't breathing heavy and I know it was off. How do i fix this?
It is easy to check your heart rate. Place your index finger on your carotid artery on your neck. count the pulse for the seconds. multiply by 6 for beats per minute. If it does not match your monitor contact customer service for repair. If it does match your monitor call your cardiologist.
http://www.raytech.ca/en/services/repair_service.asp
SOURCE: garmin 205 and heart rate monitor
What is the problem?
If you are looking for a heart rate monitor, one can be found here.
http://www.gpscity.com/garmin-heart-rate-monitor-with-soft-strap.html
SOURCE: I have an issue with
first make sure,all the button is functioning,then go to menu and try all function and observed,what the result,if nothing happen,try the long press,most of all the setting is by means of long press.
SOURCE: Garmin Forerunner 50 Train Display Settings
I was having the same problem and came across your post - I figured out how to change the secondary display. While in Train mode, with your foot pod activated, hold the View button. The secondary display will change and say "CAD" or "PACE"...keep doing this until you get to the right display. Hope this helps!
SOURCE: heart rate zones
Heart rates are known by the garmin software as zones, numeroted 1 up to 9.
You can set on the software your heart rate, based on :
- HR max ;
- intermediate HR, linked to the zones.
Then, when you upload a session in the software, you will analyze the zones you ran in.
Another tip : to set on the Garmin itself, the Zones to ON,then Z0 to ON, and Z0 HRM to ON : here you can indicate your HRM low (ex : 165 for me) and the HRM High (185 for example). Then during your session, an up or down arrow will appear, indicate if you run below your HRM low (aerobic zone), your anaerobic zone (betwin HRM Low and High) or in VO2 max.
Hoping that's clear and that can help you.
SOURCE: The watch wont find or pair with the heart rate
you can find an exper in the local shop where you buy the product and they will give you specific service for your questions about your product.
In addition, and i like to play world of warcraft. there is a reliable website for
all players to get gold for wow with the lowest price wihit in 10 minutes' fast delivery and you also can enjoy first class service
for your login.
