Televison & Video Logo
Posted on Apr 04, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Emerson flat screen tv, 32 inch, model number LC320EM2F, will not come on
Will not turn on
Sonny Berry
Level 3:
  • Emerson Master 8,617 Answers
  • Posted on Apr 04, 2013
Sonny Berry
Emerson Master
Level 3:
Answers
8617
Questions
Helped
1723411
Points
23750
Does the digital television come up on the screen for a second then it goes black? If so its usually the inverter which has the issue.
  • Lisa Scott McLain
    Lisa Scott McLain Nov 11, 2013
    MINE WILL NOT COME ON AT ALL ANY SUGGESTIONS
5 Related Answers
freetek
Steve Allison
  • 5569 Answers
  • Posted on Jul 07, 2008
SOURCE: Emerson flat screen tv with red stripe
The pixels on your screen are controlled by a matrix composed of switches that turn off and on to produce light.
They are located vertically and horizontally, row-wise and must function together to produce everything from black (everything turned on so no light, or very little, can escape) to layers that represent the three colors that are used alone or in combination to produce the millions of possible shades of each.
One of the switches that controls one of the vertical columns has failed and has turned on the entire column that allows red to display.
The problem switch (a semiconductor combined with many) is permanently turned on, probably part of the screen assembly itself, and was placed with others by robots.
The pin spacing on these 'chips' is very small and often makes the assembly unrepairable.
While LCD panels have fallen hugely in price, you may be looking at a parts cost (labor is probably not too bad) that may make you decide to replace the set.
Unfortunately, the once-proud Emerson name has sadly been degraded and there is a lot of their electronics available from companies that specialize in 'refurbished' products, an indication that they have a large failure rate.
Anonymous
  • 56 Answers
  • Posted on Feb 02, 2009
SOURCE: remote control code for 32 inch lcd EMERSON TV
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv t
Anonymous
  • 1077 Answers
  • Posted on Feb 07, 2009
SOURCE: Can't see the top or bottom of screen on my emerson 32" Flat Scre
If it's like mine, there should be a screen mode button on your remote. Keep pressing it to change to different settings.
dave1645
Dave Naylor
  • 834 Answers
  • Posted on Sep 20, 2009
SOURCE: I have a 32 inch Emerson tv..model # LC320EM8AN
t-con board is failing have a tech replace it
Anonymous
  • Posted on Dec 31, 2009
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
1helpful
I was wanting to know can you put parts from a 32 in tv into a 50 in tv that quit working with them also being 2 different models?
Parts are normally rated to the size of the TV. I doubt if the parts are interchangeable. You will need to read the ratings on the parts to make sure they are compatible with each other. You also need to consider the connectors, they are all different sizes with the number of pins in them.
2answers
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
I'm looking fit Bluetooth pairing codes foe an Emerson 32 inch LED flat screen TV
You didn't list your model number, but I seriously doubt that any Emerson branded television features Bluetooth.
Need a power mother board for a emerson 32 inch tv model number lc320em2
does anyone have the part # for the power inverter transformer for the LC320EM2 A the board #BA1AFGF0102 2. The transformer I am looking for is the largest yellow transformer, thnks.
1helpful
HOW TO CONNECT AN EMERSON LCD 32" TV (LC320EM2F) TO MY LAPTOP
YOU NEED EITHER A TV CARD OR HDMI CARD INSTALLED IN THE LAPTOP. BUT MOST ALSO HAVE A 15 PIN MONITOR CONNECTOR INSTALLED ON THE TV AND LAPTOPS USUALLY HAVE THAT JUST BUY A MONITOR CORD
2answers
Emerson tv model LC320EM2F
I will send you the manual if you email me at [email protected]. Please put "emerson LC320EM2F" as the subject or you can go to www.emersonaudiovideo.com/support/download.php
Emerson tv lc320em2f manual
where is the zoom button on my LC320 EM2 flat screen tv?
2helpful
2answers
1helpful
2answers
Remote control code for 32 inch lcd EMERSON TV
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
