With the tv laying flat on to the screen, remove the two screws in the recessed holes. Then remove the two screws above towards the input panel, one under AUDIO-L/AUDIO-R and the one under HDMI-1. The stand should easily slide out.
To remove the stand of your TV look at the manual on page 31. The 2 holes in the center bottom has a sreew in it remove the screews and the stand should come off. Hope This helps. If not look at page 31 on the link below. you can see the 2 holes an inch above the senter of the stand.
http://www.oncorpus.com/down/ENG/UM-32LB30Q,26LB30Q-%20E%206.21-6%20.pdf
Good Luck and Please Rate FixYa!
Remove four screws on back of tv above the stand. The difficulty is that when the stand was slid onto tv base and into mounting bracket, plastic clips on the stand locked on to mounting bracket inside the tv and cannot be released without cutting or breaking them. The bracket will slide down and out of tv when you remove the four screws.
Hih
