When turn the TV on the picture never comes on but the sound comes on. After awhile the TV turns off.
SOURCE: Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
SOURCE: Mitsubishi WS-65809 turns off right away
check 2 5amp chem fuses. in middle of tv. yellow or orange in color . if bad replace the 2 stk convergence ics and fuses.
SOURCE: mitsubishi rear projection tv won't turn on
know problem of bad caps.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The
DM board is the one with the digital connectors on the back panel. If
you already have it appart, you may as well check the caps on all of
the boards. The caps that go bad are typically Jamicon brand caps in
1000 uF and 330 uF values. There are also a couple of 3300 uF caps in
the PS that cause problems.
SOURCE: WD-52631 Red Light-No Picture, still have Sound
unplug it from the wall, wait 30 seconds, then plug it back in. i had the same problem and this simple solution worked for me. Good Luck!!!!
SOURCE: Has Sound but no Picture and shuts down
I have the same tv and the same problem happened to me (Actualy twice). It turned out to be the color wheel motor. thats what the clicking noise is.
