2 red lights are continuously blinking
SOURCE: two red light blinking
Do you see any flag message like " end of service life-------". You should find a resetter for the printer, its a utility program.
Or its a paper jam, or dirty ink chip connector.
SOURCE: green & red light is blinking
If you try to print and it say "end of service life ........thing" . You have to reset the printer counter to 0 count.
Use a third party software for this, key in in your web search bar " epson reset software" the upper most link is the one, try to read the procedure.
Hope you get it easily.
SOURCE: Epson stylus CX5500 series, 2 red lights are
you can download a reseter just to be sure you also replace or wash the ink pad... replacing or washing the pad is difficeult bcoz you should dismantelle the cx5500 coplettely you should have an advance technician skills to do it...
SOURCE: My Epson Stylus R230 has both red lights blinking
Your printer has reach its maximum count of cleaning and printing. This need to be reset using epson adjustment program. But before resetting make sure that you have replace the waste pad inside your printer or it is much better to point outside the hose where the waste ink goes out.
SOURCE: (Epson Stylus C60)red light blinking, says contact
keenepadgl, "Contact service engineer" for a C60 used to be all you could do. Now you can go to SSC Service Utility and download it. But the red light blinking (if that is all that is happening) simply means you have a ink cartridge that is low but not empty. If the red light stays on, then it means a ink cartridge is empty. By downloading SSC Service Utility you can solve about any problem you have with a C60. That's what the "Service Engineers" use. Check out the protection counter reset in SSC, that is the main reason people had to send their C60s to have serviced., and what service would do is press the reset button in SSC program. NOTE: I would go to inkmizer and get some cleaning fluid instead of nail varnish remover.
