SOURCE: maytag washer
replace the micro switch and your problem is solved.Its a very small switch right next to your door switch and fuse.It has 3 wires and must be replaced to fix this problem.
SOURCE: maytag hav2558aww wont spin/drain
Your drain filter is clogged with debris. Usually small items like
dirt, paper, money, and much more. Clean the filter and you should be
set to go.
I hope this information allows you to resolve this issue. If you need
further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take
just a moment to rate this post....thanks!
SOURCE: Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
SOURCE: maytag washer will not agitate during wash cycle
http://appliancejunk.com/forums/index.php?topic=2946.0
Above is a service manual this will show you how to troubleshoot and repair.
SOURCE: MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12,
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
