True T-23F 23 Cu. Ft. 1 Door Freezer Logo
Anonymous Posted on Apr 06, 2013
T-23f true freezer compressor makes rattling noise then starts sometimes i believe it is the over temp compressor relay
Robert Frank Sr.
Level 1:
New Friend:
  • Contributor 39 Answers
  • Posted on Apr 18, 2013
Robert Frank Sr.
Contributor
Level 1:
New Friend:
Answers
39
Questions
0
Helped
10049
Points
39
Replace the current relay and overload and start capacitor.
look for any looe or damaged wiring as well.
3 Related Answers
A
Anonymous
  • Posted on Apr 11, 2008
SOURCE: True Freezer Running Too Cold
thermostat is stuck closed, if not compressor relay is stuck closed, if not then the defrost timer is stuck closed. test the components in that order.
Anonymous
  • 30 Answers
  • Posted on Mar 07, 2009
SOURCE: convert freezer to refrigerator
Converting a freezer to run like a fridg can be done ,however it is sometimes tricky. you have to replace the thermostat, you will also want to shorten the defrost time setting. and may have to disable the fan delay to let the evaporator fans run all of the time, to prevent short cycling of the compressor.
Anonymous
  • 45 Answers
  • Posted on Apr 06, 2012
SOURCE: How To Replace Relay On True T-72 Reachin
If it's mounted inside a box along with the capacitors there is 1 screw holding it from the back. Often you have to unmount the box from the compressor to access the screw.
True T-23F Single door freezer. My freezer isn't running?
Question edited for clarity and better English.
Low on Refrigerant Gas. You need a refrigeration engineer.
Compressor not working
REPLACING TRUE AIR FREEZER COMPRESSOR
True freezer model t -23f need wiring diagram
There is a safety cutout on the evaporator that sometimes goes open circuit, stopping the heater coming on in defrost.If the compressor will not turn off, check the condenser is clean.and the fan working. next check the thermostat hasn't broken. Lastly, check the defrost timer.
Regarding replacing the temperature control on the True t-23f freezer, I can't find it.
As soon as you open the freezer door the temp control is at the upper right of the freezer.
2answers
We have a true single door freezer, it is iced up inside . what should the dial inside the unit be set on.
On the freezers a setting of 7 or 8 should do fine. I would be more concerned with the defrost timer, defrost heater, and settings. Also a HUGE problem is that the door switch on the top center of the door can sometimes barely contact the door (this happens when a unit is slightly warped or out of level) or the spring loaded hinge on the door can break causing the door to stay propped open at times. When the door doesn't close the evaporator fan stops but the compressor will continue to run. I have had to tape a nickel on top of the door to make better contact with the switch. Make sure the switch isn't the problem before going any further.
2answers
2helpful
2answers
Our refrigerator/freezer was making a clicking noise this morning and then the temperature started getting warmer. Now it's not cooling at all. It's only (4) yrs old.
pull the unit out
unplug it
take off the back panal
on the compressor it self
you will see the wires connected to the relay and overload
if you pull them off the compressor give em a shake
if you hear a rattle thats your problem
ohhh it does not need to rattle , but you can ohm it out to check but those are your problems
Oct 09, 2009 • Freezers
2answers
True Freezer- The 5 amp circuit breaker trips when the light on
I believe that breaker is actually for door frame heaters. Most true freezers have a resettable breaker for the door perimeter heaters only.
2answers
T-23F FEERZER
fan burnt or relay fauly or fuse blown
Top True Freezers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a True Freezer Expert? Answer questions, earn points and help others
