Hey there, here you can find a proper list of all the error codes together with solutions: Solved HP Printer Error Code Cheat Sheet
Hope I helped!
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
SOURCE: error code 49.4c18
49.XXXXX ERROR
A critical firmware error has occurred.
Turn the device off and then on.
2. Try to determine whether the error
occurs intermittently, while printing, or
when turning on the device.
3. If the error appears while printing,
determine whether it occurs when
printing from a specific computer, a
specific application, or a specific file. If
all other computers, applications, or files
can print without the error, then the
problem may be only within one print job
or computer. Make sure the computer
has the most current printer drivers, or
use a generic printer driver.
4. Go to www.hp.com/support/LJP3005.
Click Download Drivers and
Software. Check for the latest firmware
image version at the bottom of the page.
If this firmware image is newer than the
one installed on the device and the
device can receive a firmware update,
download the newer firmware upgrade.
5. Try printing a job from a different
software program. If the job prints, go
back to the first program and try printing
a different file. If the message appears
only with a certain software program or
print job, contact the software vendor for
assistance.
6. If the message persists, contact
HP Support.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: hp 2300 laserjet printer error code 13.20.00
this problem persist NVRAM resetting
To perform an NVRAM initialization, complete the following steps:
1 Turn off the printer.
2 Press and hold (DOWN arrow), and turn on the printer.
3 When all three status lights are lit, release (DOWN arrow) and press (UP arrow).
4 Press PAUSE/RESUME. The first item of a menu appears.
5 Use (UP arrow) or (DOWN arrow) to scroll to NVRAM INIT, and press (SELECT).
cihat ALTIN FROM TURKEY ANKARA
SOURCE: HP LaserJet M1522 with error 49
on hp.com you can update the firmware and that should take care of it. its a free download
SOURCE: Hp laserjet 2300 printer is making a shadow copy
The Hp 2300 shadow problem is either the supply/toner or the fuser
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
