1993 geo storm won't shift down buy itself going up hills.works manually. If I push pedal to the floor hard it shifts for a few seconds
SOURCE: no reverse sometimes geo metro a/t
The accelator cable is "Y" shaped. one side goes to the carb and the other to the tranmission. If you have the carb.side too tight it will give you the problem that you are having.
Robert
SOURCE: geo metro transmission slips and
Auto Trans I had to replace solenoid in transmission there are two of them when you drop the pan. After testing with a 12 volt battery one was bad replaced and transmission works fine. Mine was a 1996, cost about $90 for solenoid.
SOURCE: transmission won't shift from low gear .
Check you transmission fluid if its thin theres your issue if not it could be your bands or your torque converter.
SOURCE: Geo tracker wont shift after clutch and clutch cable replaced
this is common.
it is caused because NO ON ever changes the cable at 100k miles.
it then wears a groove inside the cable and jams where you cant see.
(got my car dirt cheap cuz no one could figure this out)
the next thing to happen (toss coin) is the fire wall cracks or the clutch pedal spline strips.
full story here,
http://www.kick-fix.com/tranny/clutch/clutch-on-kick.html
now you know the why , so now correct all the damaged caused by a $45 cable.
all parts are at suzuki , every single one.
SOURCE: 95 Geo Tracker - Automatic. Starts ok, but when
It needs a fluid change,and filter,in the transmission,also,add a additive called LUBEGUARD from napa auto parts,when you ask for the additive,be sure to get the one for gm,this additive keeps the valve body slick,and moving,this is the problem,your filter,and ,or,the fluid is dirty,and causing hydraulic problems,and valves to stick in the valve body in the transmission.
