Question about Hoover Nextra HNL 3166 Z Front Load Washer
Cant remove my filter on my hoover hd vision washing machine
Wont drain
6ya staff
SOURCE:
danbhoy
SOURCE: Hoover Vision 1600 drum not spinning?
I have similar problem with same model unit, found brushes on motor worn to point copper contact is hitting and scoreing commutator. Easy checked, ensure power completely disconnected, lie machine on side and gently rotate drum looking in side the motor. The commutator is what looks like a circular block of copper segments which will rotate with the drum and should be evenly worn and coated with carbon from the brushes. If you see a clean copper area, usually in the center, then the brushes are worn down below workable levels. Suggest replacing should resolve problem.
Posted on Jun 08, 2008
Anonymous
SOURCE: my hoover washing machine 1400 spin 8kg hd vision hd
Hi On my washer when I press the start button when allready in opperation all the lkights flash and it stops as this second press of the button pauses the machine and need the start button to be pressed again to restart the machine
Hope that is cleas and helps
Angela
Posted on Aug 15, 2009
Anonymous
  • 3 Answers
SOURCE: How do you remove the filter for a Hoover washing
I included a link on Youtube to my Nextra where I show how I clean the filter (watch it from 08:55 onwords). Just remove the kick strip and unscrew (philips screwdriver needed) the little screw on the filter itself, then turn it anti-clockwise but while you're doing this make sure you insert the kick strip underneath to gather the residual water. Repeat this operation 3 o 4 times until the sump is totally empty, make sure you don't let the kick strip fill up too much otherwise you'll be spilling water all over the place, so just turn the filter clockwise everytime you want to stop the trickle of water. It's not too complicated and it won't be too messy if you follow these instructions carefully. Good luck ;-)
Posted on Nov 05, 2009
Anonymous
  • 3 Answers
SOURCE: hoover optima hnf6167 7kg washing
My washing machine completes its cycle but is leaking water from the left hand side on to the floor, Why is this???
Posted on Apr 25, 2010
swatpakistan
  • 3 Answers
SOURCE: hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
Posted on May 13, 2010
Hoover vision hd
the bearing are gone
Jan 18, 2014 | Washing Machines
Hoover vision hd 1400 aaa manual
I have hoover vision hd 1400 aaa
In proble stain blaster
I oll redy clean thing and check water vest pipe
Nothing to blocking
Jun 16, 2013 | Hoover AAA140 Front Load Washer
Hoover vision hd 8kg door security button flashing
i now have same problem- did you get a solution?
Feb 17, 2012 | Hoover Washing Machines
After a power cut my washer wont work the door security light just keeps flashing! Model Hoover Vision HD
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
Apr 24, 2011 | Hoover Washing Machines
Hi i was wondering if you help.my hoover hd vision
May 12, 2010 | Hoover H160E Front Load Washer
Hoover vision HD 1400 AAA 8kg washing machine - wont start & four flashing lights on timer delay ?????? any advice pls
can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
Feb 01, 2010 | Washing Machines
The water does not get pumped out of the machine
The filter is to be found at the bottom front left of washer behind a removeable plastic trim, if you can see a screw in the filter cover, undo this, and turn filter anticlockwise to remove.
If no filter at front, then remove rear panel of washer, and remove large black hose fastened to drum, check for blockage here, and check the pump at the same time.
Thanks
.Please rate my solution;
Nov 08, 2009 | Hoover AAA160 Front Load Washer
Hoover Nextra HNL 3166 Z Front Load Washer Logo
63 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
