It can run without the throttle cable as long as where you pointed in video down by the motor, you get a piece of wire or clamp or something of that sort to keep it open. Problem is it is hard to control what speed of rpm. Best would be to order a whole new throttle cable. They come complete in line and they are real easy to put on as you can see there is only a couple screws that hold them. The throttle cable is only designed like your cars gas peddle would work. As you press the gas peddle it opens up the carb to put more fuel in.
Thank you for the help. One more thing should I buy a lubricant to loosen up the throttle a little I noticed its really hard to move and If so what kind would you reccomend ?
The throtte cable most likely is stuck do to it fraying apart. Just plain warn out. However you can try and spray on the parts you can get to. Do not use wd-40 that is not good as it just gathers dust and debre. Go your local auto parts store, they actually sell cable grease designed for this, almost like the same stuff they use on motor bike chains.
