SOURCE: how do I reset protection counter for epson dx 7400
If the counter needs resetting you should have an error message saying that "parts inside your printer have reached the end of life" (If not then it is NOT the waste ink counter). If so then your first call is to the Epson Support site:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
You could also try third party utility's such as this one:
http://www.ssclg.com/epsone.shtml
Hope this helps, please take a moment to rate this solution. Thanks
SOURCE: my printer epson r230 is not working. the two red
my printer epson r230 is not working. the two red light are blinking. is it my counter reset is end?
SOURCE: reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
SOURCE: T11 Counter Reset
SSCLG can not counter reset the new T Series printers... please check
http://inksystem.vacqum.com
There is an adjustment program for T11 you can download..
follow the readme file and you are good to go
SOURCE: How to reset the counter to 0. Is it legal for
First off to reset the counter Press and hold 'stop' 'maintenance' and 'power' buttons for about 10 seconds, a message will come on the screen saying counter is reset and to turn off. Now 2nd yes it is legal for them to put unrepairable as it is telling you the life on something in the printer which they do not repair is at its factory designated wear out time. Well obviously this probably isnt the case but usually give it enough time and it will be. If you have further questions please feel free to follow up with a comment. thanks, Midwest-tek
Testimonial: "I WILL GIVE YOUR SOLUTION A TRY. MANY THANKS FOR YOUR PROMPT REPLY."
