My sony lcd tv model klv 26s550a having continuos red light blinking problem. please tell me how to solve it
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
SOURCE: Sony Bravia KLV-40S200A LCD TV standby indicator blinks 5 times
hi i have a sony bravia ex710 .dont power on .and leds lcd 5 star
SOURCE: Good afternoon, Sirs! I bought an
Hello AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with
Blinking of standby light is Sony TVs are fault indication. Five blinks denotes
the video. You must have some knoledge in electronics and ability to follow the schematic diagram of TV otherwise called as circuit. Must have a high quality digital multimeter, soldering iron and a concept of soldering. I'll assist you. Must have confidence and more patience. If you have these, inform me by Fixya. I'm happy to assist you. If not, get it repaired by Sony Authorised service center. Any service center, who takes this set for repair, must have all the testing equipemets like oscilloscopes, clour analiser, pattern generator and AVO meter. Without these testing equpments, trying to repair this set will make things mor worse. OK.
SOURCE: Sony LCD TV Model #KLV-23HR2 The timer LED
This is a common problem an a failry easy DIY fix.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
SOURCE: My klv-21sg2 sony LCD color tv red light blinks 1 second and off for 2 seconds
OCP ( Over Current Protection ) . Your TV need a thorough checkup. Contact any experienced service technician.
