SOURCE: Camera in japanese language i want in english LUMIX DMC TZ5
Select menu
Select spanner(wrench) for setup menu.
Scroll down through the menu, there are five pages of menu items on my camera! it moves to a new page when you move off the bottom.
The language option is the penultimate item - it has an icon of a head with a speech bubble.
SOURCE: hi i have the panasonic lumix dmc fx37 and the
Turn the camera on. Slide the REC/PLAYBACK switch to REC (camera icon). Set the mode dial to the camera icon. Press MENU/SET to display the menu. Press Left-arrow. Use the Down-arrow to navigate to the wrench icon. Press Right-arrow to select the Setup menu. Navigate down to the icon of a face in profile with a speech balloon. Select that, then select English.
SOURCE: how do you change the language settings on a
Language should be the second-to-last item on the Setup menu.
SOURCE: language change from japanese to english
Slide the [REC]/[PLAYBACK] switch to the REC position (camera icon). Set the mode dial to AUTO (green camera). Press MENU/SET to display the menu. Select LANGUAGE (head with speech bubble). Pick your language from there.
SOURCE: i cannot change the language
You can use http://translate.google.com/# to help you get the right settings.
as you can translate the common used English words to Japanese and to find it in your camera
Settings:
language:
menu:
english
it's a pity that I can't copy the translate results here as this site don't support japanese words
Wish helpful
