1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 350d service manual link:
http://goo.gl/ELh523
it will help you to save a lot of money
Hope it helps, Thanks
SOURCE: I'm using Tokina 12-24mm f4 on my Canon EOS 20D.
Most likely something bad has happened. It out of warranty, usually its 5 years. This is a pro job, getting to anything inside a lens is a very special job. There are a number of places to send it out. Check http://www.acecam.com/srindex.html and write to one or two of the places for estimates. It could be $150 or more plus shipping and taxes. A new one is about $400+, you could check around the many on-line camera stores for a used one. Could be a simple electronic part or the iris blades are bad.
SOURCE: Nikon mount 60-300mm tokina lens want to fix in Canon EOS
Here is an article describing the process and giving some links to the necessary adapter.
