Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Sc629 error error sc629 ricoh 1515 help me
6ya staff
SOURCE:
Anonymous
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
Posted on Jun 23, 2008
Joseph Micallef
  • 86 Answers
SOURCE: ricoh 1515
Turning the main power switch off and on, resets the SC code if the error is caused by incorrect sensor detection.
If the error is still there, the laser synchronising detector or laser diode is faulty. Please call a service engineer.
Good luck and please rate me, thanks.
Posted on Jan 21, 2009
Anonymous
SOURCE: Richo 1515 MF Error message: 12320 couldn't find the scanner.
The scanner had been previously configured and did work on another PC that crashed. We used adobe 5.0 to import. (obv this was awhile ago) I remember having this problem then but I don't remember how we fixed it.
It's a MF and the PC can print to it, but I can't get the scanner to communicate.
Any help appreciated.
Posted on Feb 27, 2009
Ekse
  • 13434 Answers
SOURCE: I have a Ricoh Aficio
Does the machine show up on your computer - you can print?
do you see it in scanners and cameras in start - control panel -> scanners and cameras? what is the status shown there on the properties?
Posted on Jul 30, 2009
Leon Robinson
  • 747 Answers
SOURCE: ricoh aficio 1515 with error code sc 392 and i
lets see if its a driver problem go to start go to devices printers now you should see your printer on the bottom half right click it the trouble shoot it the its going to ask you to fix then fix windows will take from there.
Posted on Feb 04, 2011
Ricoh Oficio 1515 tengo el eror SC 541
Fusing thermistor open error
Symptom: The fusing temperature remains lower
than the specified temperature by 20
degrees Celsius.
Possible Cause:
• Defective thermistor
• Incorrect installation of the thermistor
• Defective power supply unit
• Loose connectors
Dec 04, 2010 | Ricoh Aficio 1515 All-In-One Laser Printer
I need help for my printer RICOH AFICIO 1515
Here is the link to Ricoh's website and the 1515 drivers. Just select your PC's operating system.
Good Luck and Thank You for using Fixya.
Please return and give me feedback on my solution.
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x15_15f/x15_15fen.htm
Sep 25, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
WHAT RICOH PRINTER IS COMPATABLE TO THE RICOH AFRICIO 1515
The 1515 is compatible to the 161 and the 171, the two newer generations of similar printers. All three use the same toner and photoconductor units, and are set up almost identically.
Nov 20, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
I have a Ricoh Aficio 1515 MF. I cannot get my Windows XP Pro to recognize the scanner, and I downloaded the Twain driver from the Ricoh site. Help! I want to scan into Adobe Acrobat.
Jul 30, 2009 | Ricoh Aficio 1515 All-In-One Laser Printer
Ricoh 1515
Jan 13, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh 1515
a minha ricoh 1515 vem apresentando constatemente o codigo cs 929, como fazer para solucionar este problema. pois os tecnicos não resolvem.
maninhosales@hotmail.com.
emmanuel buonafina.
fone 81 32425587
81 86123213.
May 28, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Aug 19, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
44 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
