Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera Logo
Posted on Apr 09, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My canon ixus cannot switch on - Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera
Art Scott
Level 2:
Novelist:
  • Canon Expert 357 Answers
  • Posted on Apr 11, 2013
Art Scott
Canon Expert
Level 2:
Novelist:
Answers
357
Questions
0
Helped
68884
Points
473
Make sure the battery is charged. Check the battery door switch and that the battery door fits tightly. You can see the door switch through a cutout in the door frame. It is very small. You can usually bypass it if it is broken. First you have to figure out if it is always on or always off when the door is open. If it is always on then just remove the switch. If it is always off (and turns on when the door is closed) then solder a wire to connect the switch's contacts so that the camera thinks the door is closed.
Note: this solution requires precision soldering and experience
Other possible causes: blown fuse (usually found near the DC in plug), main circuit failure
When I pressed the on/off switch of My Canon Digital Ixus 860 IS, nothing was happening except the focus sensor was on
Canon Digital IXUS 860 IS Review
(also known as the Canon Digital ELPH SD870 IS) Pause
Unmute Loaded: 0%
Progress: 0%
Remaining Time -0:43
Fullscreen X
Leave a comment about this Review
Page 1
Introduction / Ease of Use Page 2
Image Quality Page 3
Sample images Page 4
Design Page 5
Specifications Page 6
Conclusion
Introduction
Promoted as "the photographer?s IXUS" by Canon, the new Digital IXUS 860 IS is one of the more intriguing models in Canon's Autumn lineup of compact digital cameras. The new Canon IXUS 860 IS offers an 8 megapixel sensor and a wide-angle 3.8x zoom lens equivalent to 28-105mm, complete with optical image stabilisation to help ensure that your photos are shake-free. There's also a large 3 inch LCD screen with 230,000 pixels and an anti-glare, scratch-resistant coating. Canon's DIGIC III image processor, which is also used in its DSLR camera range, powers the IXUS 860 IS behind the scenes, and additionally provides the camera's Face Detection and Noise Reduction technologies. There's a new Red-Eye Correction feature on offer in Playback mode, a range of ISO speeds up to 1600 and a new ISO Auto Shift function to help avoid image blur whenever camera shake is predicted. So is the stylish Canon Digital IXUS 860 IS really a great compact camera for the more serious photographer? Read our in-depth review to find out.
Compare Prices
Support PhotographyBLOG: Buy the Canon Digital IXUS 860 IS from one of our affiliate retailers:
Ease of Use
The Canon Digital IXUS 860 IS is a very well-made compact digital camera, with a stylish two-tone black and silver metal and plastic body and excellent overall finish. It has a pleasingly simplistic, clean overall design, with a pronounced curve on the right-hand side (looking from the back of the camera). If you require a pocket camera that is good-looking, then look no further - I'd go so far to say that this is the most well designed IXUS yet. The Canon Digital IXUS 860 IS is easily small enough to fit into the palm of your hand, weighing 155g without the battery or memory card fitted. Most aspects of the design and build have a quality feel with nothing really feeling flimsy or ill-thought out. There are a few minor criticisms that can be leveled at the Canon Digital IXUS 860 IS, mostly concerning the various covers. The plastic A/V Out / Digital port cover on the right side of the camera feels a little flimsy, as does the battery/memory card compartment cover, which is also trickier to open than it really should be. Otherwise the Canon Digital IXUS 860 IS scores top marks for its general design and build quality.
4helpful
My canon digital camera ixus 75 card is locked how to procedure to unlock
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
2answers
Confused over which battery pack I need for Ixus 700
What are you confused about? This is the correct replacement battery.
http://www.buy.com/prod/replacement-nb-3l-li-ion-battery-for-canon-powershot-sd10-sd100-ixus/q/sellerid/16427119/loc/111/208166814.html
2helpful
Canon ixus 75 card reader locked
Move the slide switch on the side of the card.
3helpful
Card is locked of CANON IXUS 960IS
There is a little slide switch on the side of the SD card that will lock it.  It could be that it got bumped the last time it was inserted, or the memory card could be defective.  I saw this happen with a SanDisk card that hadn't been removed from the camera.  Removing the card and sliding the lock switch back and forth, then re-inserting finally solved the problem.  It was a bit disconcerting when it happened.  I would recommend that you get a replacement memory card to use if it starts to happen repeatedly.
1helpful
2answers
Canon ixus 50 the camera is not switching on and the lens is open
Check the battery cover closes properly, the camera will not operate at all if the switch thinks the cover is even slightly open. Try removing the card, sometimes they cause cameras to not start when they are faulty. If all else fails, the fuse is most likely blown. They are internally located just near the power switch but you are best to have a service centre replace it for you. Best of luck.
Canon
It is an excellent 10 MP compact camera. Still expensive when compared to similar models, but if you don't mind about the price it is a grat camera.
In its category is also one with the best image quality (Canon IXUS 85 IS test shots)
Here you find technical specifications: Canon UK
Canon IXUS 85 IS Review | Canon
Check:
Canon Digital IXUS 85 IS
Reviews: Canon Digital IXUS 85 IS
Don't forget to rate the solution.
Thanks
Canon digital ixus 70 pdf manual
My Canon Ixus 70 will not switch on although the battery seems fully charged have you a solution please or does anyone have similar problems and their possible solutions thanks,
Bazzeruk
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
