Mixer 5kpm5 motor doesnt seem to go round freely
Does the beater shaft turn when there is no load? (bowl is empty) Or it will not turn at all?
It sounds like you have a stripped gear. Your mixer has a nylon/plastic gear inside the mixer and that is 99% of the time what goes wrong. You will want to open the mixer up and inspect all of the gears, but most likely you will need to replace the worm gear, part number W10112253.
Here at MendingShed.com we sell Genuine KitchenAid parts and the items can be found on our website.
Here is a link to that gear: http://www.mendingshed.com/kawormgear.html
You may also want to replace the grease and gearbox gasket while you have the mixer opened up.
We also have a service manual posted on our website which will aid in taking the mixer apart and putting it back together properly.
Service Manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
SOURCE: kitchen aid mixer 5kpm5 motor doesnt go round freely
Any appliance with a motor should rotate freely. These are basically gear driven devices, Kitchen Aid makes different quality equipment. So either the gears are worn or possibly if you notice an electrical smell the problem could be at the tail of the motor. there are 3 major components 1. the brushes where the armature spins if you look inside the vent holes you might see a slight arc while it is running 2. the tail piece which is how the motor is kept straight. or as I said worn gears. this is especially common when companies use plastic gears instead of metal ones. Commercial appliances made by people like Hobart are expensive, but they outlast most others..
