Collate & Staple and Holepunch options are greyed out so I can't select. Company-installed driver is iR600-550-60 PCL.
SOURCE: I want to print a document and have it collated
check in the finisher unit if staple cartridge is not empty
SOURCE: Changing staples
You cannot find it as user, it ussualy comes with some part of finisher, eg. when you order a staple crg assy. you will get and the " green holder"
SOURCE: Environment: Windows Server 2008 as Print Server.
I believe you have to identify the accesories that are on the copier. I think you go to the printers section of the control panel on Windows. Right click the copier, select properties, then device settings. Look to see if you can change any of the options. If not you may have to reinstall the print drivers. Hope this helps.
