The dryer stopped with 19 minutes on the timer. It will run in fluff mode only but of course not get hot. the conections are good and there is no obstruction in the vent hose. When i unplug let sit and plug back in the timer still shows 19 minutes. Thanks
It sounds like you have a bad computer board if it's stuck on 19 minutes and the pf is for power failure,this is only a guess,the best thing would be to call in a tech to check it so you know what the problem is,the board is expensive or you can order the board from repair clinic,if it's not the problem you can send the board back to them.did your power go out for some reason like a storm or something?this can take out any computer board
http://www.repairclinic.com/PartDetail/Main-Control-Board/33003028/1164529
SOURCE: Maytag Neptune Dryer
is the drum light on while the door is closed?? look on the teck sheet found in the lower front panel for a wiring diagram momery servers me there is a thermal fuse chances are this is bad if you cant find this tech sheet I will look in my invoice book and see if I can find the sheet for it good luck let me know what you find out
SOURCE: My Maytag Neptune gas dryer gets hot for about 30 seconds.
Below is a link courtesy of www.repairclinic.com. This shows the Gas Valve Coils, which is the number 1 failing component.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG5500AW-%3d%3di3479&PartID=3479
Below is the disassembly/diagnostic procedures page that may help on teardown.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
For more information visit, http://homemanagement.services.officelive.com/FieldServiceHelp.aspx
SOURCE: My maytag neptune dryer won't start. The control
There can be many reasons why your dryer will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
SOURCE: I have a Maytag Neptune
pf is for power failure,what kind of a smell is it,electrical or like shellac,when motors heat up it kind of smells like shellac.you can do this,open the door,remove the four fillips screws that you see,two in the door hidges and two on the other side,don't remove the door,shut the door when all screws are out and grab the front panel on both sides and pull forwards,the panel will come off and you can still run the machine,put clothes in it and run it like always and try to see if you can find where the smell is coming from,if the motor overheats and the overload pops that would kill the power going back to the board and it would be like unplugging it while it was running and give the pf code or another thing is to check the block where the power cord connects to the back of the dryer,make sure the wires are tight but i think you have a bad motor.let me ask you this,do you have to wait a while before it will start again?if so it's the motor.let mek now what you find.
