Machine works fine until the final spin. You can hear it pumping the water out. The drum turns once then stops. You can see hear the pump pumping water out. The machine does this for about 5 minutes then clicks to end. The clothes are dripping wet. Have checked pump, motor and brushes.
Any idea?
Hoover CA230 Special Edition WM: Water remains in drum after cycle is over. Have checked for blockages but found none. What do I do?
I had the same problem. My husband checked the carbon brushes attached to the motor and ran the machine on spin. The brushes were sparking so he assumed they were worn and replaced them and hey presto machine works fine now. The brushes cost 23.99 and were just bought from a local shop but can be bought online cheaper. Hope this helps solve your problem. Essex
Outlet pump is blocked with something machine thinkes it is empty, so the machine stops
