The model # for my panasonic viera is th37px60u. i want to program it to my Rogers digitial box. I have to use both remotes to watch t.v. I turn the T.v. on with the panasonic remote and put it on Channel 03 to get sound and picture. From there I can use the Rogers remote everything else.
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
SOURCE: Panasonic viera has flashing channel info in upper left corner
I had this exact same issue just yesterday. Channel info would flash
intermittently. While set was in this mode, could not enter menu,
change channels, etc. from remote or front panel controls. Similar to tjh492, I thought it might be an
overheating issue. But unplugging the Viera and waiting for set to cool
made no difference.
I then remembered that this issue popped up the instance I surfed to a
particular channel (FWIW, 26-3 "Me Too" on Comcast here in Aurora,
Illinois, USA). I had a hunch that there might be an issue with the
signal on the channel that prevented the Viera from properly syncing,
so I decided to unplug the antenna cable. Once I did that, the channel info
displayed steady. I was then able to change channels (of course screen
was blank as antenna cable was unplugged) and enter the Viera menu. I
immediately went to channel set-up and manually removed channel 26-3
from the channel list. After reconnecting cable, Viera was back to
normal. Since I'm not a big fan of "Me Too", problem solved :)
Not sure why a digital channel sync issue would effectively make the
Viera remote and front panel controls inoperable. Pure speculation, but it could
be that the Viera microprocessor was overloaded trying to sync to channel and this prevented any interrupts from remote or front panel
controls.
