Vizio M50-C1 strobing spots in the display.
A Vizio TV will flicker if there is a broken backlight, loose or faulty video cable or port, poor signal strength or incompatible display settings. Reseat all cable and connections to the television from your devices. Physically remove the cables from both the television and the device and reconnect them. If you have any of these options available please turn all of them off to see if this resolves the display flickering. lickering and shorted leds causing dark spots are both symptoms of bad leds. You can try turning down the backlight level and see if the flickering stops. The ultimate solution may be to replace the LED strips.
