You can try recharging, the refrigerant system has an electric switch for low pressure cut off that won't let the compressor turn on when there is not enough gas pressure. There is also a coolant temperature electric thermo switch that cuts off the compressor when the coolant or engine has overheated. If it's not low on refrigerant gas, then an electric problem needs to be diagnosed. A service or repair manual would then come in handy.
SOURCE: 2003 vw passat air cond blows warm air
Hi there. You have a freon leak in the system. You can charge the system and use soapy water on all joints to find the leak. If a slow leak, just recharge every year. This will get you by till you get the leak fixed.
Thanks
Paul
