I have to unplug set to get it to turn off once on no buttons work
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
SOURCE: my vizio vx32l will not turn on. vizio logo will
The main board has failed. Replace the main board will fix the problem.
By the way, where did you buy the TV? If you have bought it from Costco then try to give them a call to see if it still under warranty.
Hope this will help.
SOURCE: VIZIO 52" LCD is on but....no display
If this is indeed an LCD and not a plasma, then you need to replace the LVDS (LCD controller) board.
SOURCE: Vizio VX32L The screen goes white,no response from buttons
G'Day!
Unfortunately, what you're describing is a repair
issue. You won't be able to address the problem with troubleshooting.
There is a part inside the TV that needs to be replaced. If you're
under warranty, this will cost you nothing. If you're not under
warranty the cost will likely be a minimum of $200 parts and labor.
However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
SOURCE: my vizio vx37l will power up but it wont get any
My TV did the same thing. You need a new power supply. Fairly simple to do yourself. The card is about a hundred bucks with shipping. The part number is 0500-0507-0250. You just have to take the back of the TV off (about a hundred screws). Just unplug the old one and plug the new one in.
