? 2:22
https://www.youtube.com/watch?v=xVZUrKz2wSk
Oct 11, 2014 - Uploaded by furulevi
How to Format MicroSD card of SJ4000 sport camera. furulevi .... 64 128 GB MICRO SD CARD IN SJCAM ...
Apr 12, 2013 - When camera is turned on it says "please plug out card" What does that mean? ... put in a micro SD card and turned it on and it saying please plug out card what does that ... What does it mean if my camera says "card locked"?
Mar 2, 2014 - jazz JDC77 saying please plug card out means Just bought this ... SOURCE: I have a new Jazz DV151 camcorder and the memory card says full ... I bought an sd micro chip for my jazz dv151 camcorder, but everytime i put ..
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If this doesn't do it, try a different card.
You'll have to use the USB cable that should have been provided with your camera to plug it directly into your computer. Then you should be able to see both the memory card and the internal memory as if they were two separate cards on your computer. If you get a connection established by the cable (meaning the cable isn't damaged) but you don't see the internal memory, you may need to look for software to install before you can see it. But plug it in first and see what you find. Good luck!
Good day, This is a common problem that many people experience with their SD Cards when they are "Locked". It is normally an easy fix and you can follow a method that I posted on my tips here:
You don't say whether this is a new card or one you used before. I'm going to assume this is a new card (otherwise, it means the card has become corrupted or there is a camera fault).
You say it is an SD card, but don't mention the capacity. "SD" cards larger than about 2GB are actually SDHC cards. SD
and SDHC cards fit the same slots, but they are slightly different electrically. Many
cameras won't work with SDHC (high capacity) cards. SDHC is not
backwards compatible.
I expect your camera just won't work with this kind of card. It is often difficult to find out the maximum capacity memory card a camera will use, as today's cards are much larger that those available when the manual for the camera was written, but as a rule, if the memory size is larger than the largest size mentioned in the manual, you should expect trouble. You can always carry several smaller cards if you really need more space.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
It just means that if you want to use a memory card that is not new and was used in another camera or a computer, you first need to format it in the camera. Also, new cards should be formatted in the camera.
Choose YES for the Format option. Allow it to finish. Should work fine then.
Possible defective card if does not work after full format. Do not use any "quick format" option.
First time must be FULL format.
