Help! my client keeps getting either a 24.10 error or a 26.001 error after replacing their yellow ink.
26.0:01 is a bad contact in the Ink Supply System for the yellow ink cartridge. (This can be caused by using non HP OEM ink)
Check that the ISS to Cartridge cable is not damaged and is fully connected to the Ink Supply Tubes PCA.
You can also try switching the magenta contacts with the yellow contacts and see if the problem stays with the yellow, or you now have a magenta problem.
If the problem stays with the yellow, then you will need to replace the Ink Supply Tubes and Trailing Cable.
If the problem moves to the magenta, then you just need to repair or replace the contacts (may just need cleaned)
Good luck !
(My money is on bad compatible or refilled yellow ink cartridges)
SOURCE: HP L7580 Printer Head Problem??
Try the following
Note: If you have connected the printer to a power strip , please remove it and connect it to a wall outlet.
Remove the cartridges and print heads from the printer.
Perform power drain.
1.Unplug the power cable from the back of the
printer.
2.Press and hold the ok and help button.
3.wait for 30 secs
4.Plug the power cable back to the printer
Comes up with an msg to insert the print heads. Shake
the print heads well (8 times) and insert it.
If there is no problem with the print heads .......
Comes up with the msg for cartridges.Shake the
print cartridges well (8 times) and insert them.
If there is no error message regarding the alignment failure.
Turn the printer off and turn it on.
This should begin the with the initialization process of the printer.
This may fix the problem.
Please revert back if you have any problem.
Shijesh.P.V
[email protected]
SOURCE: False empty ink cartridge message
Here is one of the solution for the issue.
check if the serial number of the printer starts with MY66xxxxxx, MY67xxxxxx, or MY68xxxxxx. If your printer has a combination of any one of the above mentioned serial number, then try to replace the ink cartridge and you can replace the printer if it is covered under warranty.
The yellow ink sensor could be corroded and giving a false message.
SOURCE: Keep getting replace yellow ink cartridge error message
Where did you get the error message on printer or computer?
If you get the message on printer remove all cartridges and reinsert the cartridges and align the ink cartridges. If the alignment page prints successfully then the problem is resolved.
If you get the message on the computer disconnect the usb from computer. uninstall the software and reinstall the full feature software by selecting connect USB later.
