Question about Sears Kenmore 6.0 cu. ft. Gas Dryer, White Model 70022
Removing panel to install conversion kit
Trying to in LP conversion kit but can't remove panel
    New Friend:
  • 30 Answers
Some panels can't be removed from the back but from the Top and Front only. Check the Front and the Top
Posted on May 27, 2014
6ya staff
SOURCE:
I'm looking for natural gas conversion kit for a Vermont Castings Radiance Model 2240 currently LP gas fired freestanding stove
Try going to www.ibuyfireplaceparts.com 1-888-634-4289..They deal directly with the manufacturer and would be able to tell you if a conversion kit is available and how to go about ordering it
Jan 25, 2013 | Kitchen Ranges
WE HAVE A BRINKMAN GRILL AND BOUGHT THE LP TO NG CONVERSION KIT THAT IS RECOMMENDED FOR THIS GRILL ...KIT HAS TOTAL OF 6 ORFICES AND THE GRILL IS A 5 BURNER, WITH SEAR AND SIDE GRILL SO THAT MAKES 7..NOT...
Some Brinkman grills have the LP orifice installed on the NG orifice directly from the factory.
If that is true, you remove the LP orifice and the NG orifice is already there. Check instructions in the conversion kit and look for this detail carefully. I just did a Brinkman conversion and instructions were very confusing. The orifices in the kit are not used (on my unit).
Gary
Aug 21, 2011 | Garden
How do I change my whirlpool super capacity 465 from natural gas to propane
The documentation for Whirlpool appliances is available here: http://www.whirlpool.com/custserv/index.jsp . Enter the full model number from the oven rim inside the drawer. The installation guide will walk you through the conversion. However, it is recommended that a qualified technician (for LP, if going to LP) do the conversion. Most LP companies will have someone who can perform the conversion. The conversion kit should have come with the documentation for the range.
I've found one model of Super Capacity 465 with the model number SF325PEEQ0. The documentation is here: http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?form_state=literatureSearch&context=&siteCd=WHRCOM&form_state=literatureSearch&searchTerm=SF325PEEQ0 .
The steps: Make sure the power cord is disconnected, the gas supply is turned off and the grates and burner bases are removed from the top burners. Open the broiler door and locate the regulator, remove the cap from the regulator and turn it over so that LP is visible. Reinstall the cap. Do not remove the regulator. Move the range out from the countertop (about 4") if it is in place. Slide a putty knife carefully between the cooktop and the oven compartment to locate one of the clips on the side 2 3/8" back from the front of the range. While gently lifting up on the cooktop surface, push in on the clip. Repeat on the other side. Prop up the cooktop and remove the Venturi plates. Then remove one orifice at a time from the cooktop, use a 3/8" combination wrench. Replace with the same colored orifice from the kit. Lower the cooktop and reinstall all of the burner bases and other parts. In the oven, use a 1/2" combination wrench to tighten the orifice hood down to the pin (2 to 2 1/2 turns). Do not overtighten. Finish installing the range except for sliding it into the final position and then check the burners. You may need to adjust the air shutter for each burner. With the burners off, remove the knobs. Open the oven door and remove three screws from the manifold panel. Pull the panel down and away from the range. With a small screwdriver, adjust the air shutters for each burner (clockwise to let in more air, counterclockwise to reduce the air). Replace the manifold and then the control knobs and check the burners. Start the oven heating and check the burner for it. There is another air shutter next to the regulator; adjust if needed.
I hope this helps.
Mar 03, 2011 | Whirlpool Kitchen Ranges
I got a GE gas range (model JGBS22) from a co-worker. She had converted it from gas to propane. I just had a plumber hook it up to natural gas but, even with the conversion manual, he couldn't change the...
There should be a set of orifices for each burner as well as the oven and broiler. When the unit was converted to propane, these orifices should have been replaced and the ones for gas put in with the conversion kit installation information. The kit should have been reattached near the pressure regulator.
If the kit was missing the orifices, then, yes, you are missing pieces. Check with your coworker if the conversion kit was missing. If you have the kit, it can be easily done by any appliance installer (or repair person) licensed for handling NG. (At least on our range, the conversion kit installation was straight forward. Every orifice was clearly labeled with the labels different for each burner and for the gas/LP kits (ABCD (NG) vs MNOP (LP)) .) The regulator is the only part that switched for LP or NG without the kit.
As I recall, the only tools we needed for the top burners were a small wrench (10 mm) and a small flat blade screwdriver. Remove one orifice and put in the appropriate replacement. Then adjust the burners so that they didn't blow out when the oven was opened or quickly turned from high to low (for the simmer burner). The oven and broiler took a bit longer. Several screws had to be removed to get at the orifices. Then the air flow had to be adjusted for the incoming gas.
I hope this helps.
(the conversion installation manual was on the counter during installation; I read it while it was open.)
Jan 14, 2011 | GE JGBS22 Gas Kitchen Range
How do i convert from natural gas to LP or Propane?
You need the LP gas conversion kit: http://www.appliancepartspros.com/Appliance-Parts/whirlpool-lp-gas-con-item-number-ap4300853.aspx . Other sources may exist. This includes a replacement orifice and a spring and the installation instructions. The orifices are swapped with a small wrench. The spring fits inside the regulator inside the blocking plug.
You will also need to remove the cap from the regulator and turn it over. This makes the regulator compatible with LP gas. It's easy to tell which side is which - each side is labeled.
However, the conversion kit should be installed by a professional trained for the job. Your local LP dealer should be able to help you find a repair person with the skill. (Improper installation could result in a gas leak.)
I hope this helps.
Dec 09, 2010 | Amana NDG7800AW Gas Dryer
What panel do I take off to get my Samsung lp conversion kit installed? Is it the front panel???
all of them... You need to remove top panel first, two screws at the back of the maching. Next remove the control panel, 2 or 3 screws attach that. Finally, remove the screws that attach the front panel at the top and two in the area where the door closes. I had to remove the door as well. There are also two or three tabs at the top that need to be gentely moved out of the way to let the front panel pivot out before lifting it off the bottom.
Sep 26, 2010 | Dryers
Need instructions and part # for lp conversion kit on MGR5765QDS
Your conversion jets are usually located beneath the hinge area or the back panel on that stove and are mounted on a plate which holds all of the LP jets in a row. there is no need to buy a conversion kit, since it is already supplied. The jets mount on the burner control itself as it enters the gas flow tube, and the oven jet mounts just before the large burner under the plate in your oven area. Just remove that large oven floor plate and you will see it.
Mar 23, 2010 | Maytag MGR5765QDS Stainless Steel Gas...
I cannot seem to get an answer from Amana as to how I convert my natural gas range to LP. According to Amana no conversion kit is needed. Yet they cannot tell me how to convert it. The model number is:...
Gas ranges usually come with LP orifices attatched to them somewhere. In a small envelope or bag taped to the back or in the drawer they should be there. The natural orifices need to be removed and the LP ones installed. If the LP orifices are not installed properly you may get irratic flame and the flame can blacken the bottom of pans this needs to be remedied immediately due to the danger of the carbon monoxide being produced. I found good instructions for LP conversion at this site : www.peerlesspremier.com/faq-rangeconversion.htm
Dec 24, 2008 | Amana AGR5735QDS Gas Kitchen Range
How do you install an LP conversion kit on a Samsung dryer
kit comes with minimal instructions. you need to remove the burner which requires removal of the top panel, control panel and front panel. (see how do I remove front panel on samsung dryer for more details). It is fairly easy, maybe an hour the first time you have done it. Pay attention to all of the instructions re the burner, do not losen any of the gas tight fittings!
Jun 24, 2008 | Samsung Dryers
Sears Kenmore 6.0 cu. ft. Gas Dryer, White Model 70022 Logo
Top Sears Dryers Experts
Andrew Taylor
Andrew Taylor
James Steuber
James Steuber
Level 1 Expert
Are you a Sears Dryer Expert? Answer questions, earn points and help others
