Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
SOURCE: I forgot my unlock code for my Coby Kyros... how
i NEED Help .. I Have A Coby Kyros MID8120 And I Got Locked Out .. I Have Been Looking Around For Help But Nothing .. If Anyone Knows .. PLEEEEAAASEEEEEEEEEEEE HELP ME .
:c
SOURCE: coby kyros factory data reset
It's better to contact the supplier for tech help, because I didn't have this tablet before.
Android 4.0 Tablet PC
SOURCE: I have forgotten my wireless
Hi!
In order for you to remove the password, you need to reset your wireless router. You didn't mention what brand and model of your router, but anyway all routers have a "reset button" just look for it on your router. It is usually found at the back of the router and it is very small, you need a pin or anything long and thin to insert into it in order to push it for about 10 seconds.
Thanks for using fixya!
SOURCE: My Coby Kyros MIDI 1125 tablet is passworded.how can I bypass that to reset it?
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the unit******
Step 1- Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
Step 2- Click on "Power Off and select "OK" .
Step 3- Once the unit has been turned off. Press and hold the "reset" button and "power" button simultaneously for eight seconds.
Step 4- The following screen will appear. Press the "reset" button.
Step 5- The Android system recovery screen will appear.
Step 6- The "Home and Menu" button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". . Press the "reset" button.
Step 8- The following screen will appear. .
Step 9- Press the Menu" button to select "Yes- delete all user data".
Step 10- Press the "reset" button.
Step 11- The following screen will appear .
Step 12- Press the "reset" button to reboot/restart the unit.
SOURCE: I have a coby Kyros
*******This procedure will delete all items (file's) and entries on the MID7015******
