Am having nokia N73M. ma friend gave me a nokia bluetooth headset just a basic one.. (multifunction key, vol + and vol - key is there).
now my problem is my mobile does not discover this headset... i think my friend didnt unpair it from his mobile.. now how to unpair it without his mobile and to use it with my mobile.. pls help.. thank u
You may be having compatibility issue instead of what you suspect may be wrong with both your phone and the Bluetooth headset your friend gave you.
Well, there is no such thing as a Bluetooth headset being permanently locked in to a phone.
As long as there is an open 'visible' Bluetooth connection option and there are devices in range ready to pair, the process to pair starts.
Whenever there are incompatibility issues, pairing two devices using Bluetooth becomes a hassle.
SOURCE: no connection withe nokia HS-36W bluetooth headset
First check your headset pair with other handsets if ok. your headset is ok. then check your hand set connection is ok.The default password of hs-36w is 0000
SOURCE: N72 - Not able to Connect Motorola Bluetooth Headset ( H500)
Hi
My cellphone Nokia N72 is not paring with Nokia -BH-102.
When i began to search , but it not connecting
By Vijeesh
SOURCE: Nokia 6600 License Key
u can download cracked ultra mp3 at www.funmaza.com after install put 0000 in register window u can enjoy the full version
IMEI 35666500043492
key 1579
imei 357932005812725
key: 37243
imei no: 359365005978790
key: 19736
imei 351546001742607
key: 20322
if it doesn't work try version 1.4
SOURCE: Bluetooth headset Nokia BH-600
You just have to press your blutooth on/off button a bit longer for 15 to 20 sec, when the LED blinking stops (noted that the LED should be turn ON but not blinking), try to search the device again with your phone. By that time your blutooth headset should be recognized by your phone, then select and enter the code 0000.
unpairing bluetooth headset without mobile ?how for k800i sony erisson. Mobile as my mobile totally dead and the bluetooth headset could not be used for other one.
i paired my mortorola bluetooth long time ago with the old fone but now i got a samsung tocco and i cant pair that together becuase the old one is still paired with the bluetooth. and need it urgently when im driving on the mortorway
Is 2018 the twelve months wires and cords change into musty?
Wi-fi chargers
