I bought an new joy stick for an quickie f11 but get three red and 4 yellow lights.
SOURCE: Quickie s-525 joystick lights blink
I need to know how many blinks you are getting ie 4 blinks pause 4 blinks pause etc. If you can count the number of blinks between pauses then we can figure out what the error is. Hope this helps
I suggest you print this out and keep it handy.
Locking/Unlocking the VSI
The VSI has a feature that enables you to
lock your power chair to prevent unauthorized use.
To lock the VSI:
1. With the VSI switched on, press and hold the on/off key. After 1 second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile indicator should ripple up and down.
2. Push the joystick to the full forward position until the VSI beeps.
3. Pull the joystick to the full rearward position until the VSI beeps.
4. Release the joystick. There should be a long beep.
5. The VSI is now unlocked.
NOTE: If the above procedure fails to either lock or unlock the VSI, contact your authorized Pride Provider.
This is the procedure to unlock the controller on a Pride Jazzy:
To lock the VSI:
To unlock the VSI:
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
To unlock the VSI:
indicator should ripple side to side.
Good Luck
mi mobility
unauthorized use.
To lock the VSI:
To unlock the VSI:
Good Luck
mimobility
unauthorized use.
To lock the VSI:
To unlock the VSI:
Good Luck
mimobility
