SOURCE: no power
Check the top of the tank, there may be 2 thermostats, one that sits on the tank and the other is in line with the element. One of those are not working.
SOURCE: Hi! I got a new Bunn VPR last week but did not
We just got a Bunn also. After you pour the cold water in the hot water comes out quick because it has 2 different water holding tanks. After you pour in the cold,it lets out the hot thats been being heated sense the last time your poured in cold.While you are drinking the hot coffee you can hear it heating up the cold you just put in it.Then after a short time it gets quiet and keeps that water hot till you make more coffee.It always has hot water waiting for you. Thats why its so fast at brewing the coffee. I hope this helps you.
SOURCE: Started making a Skeechy sound after making coffee.
It is possible there is a problem with the tank heater. Please get the model and date code located on the bottom of the machine. Then contact customer service with this information. The brewer contains a 3 year warranty and if your brewer is 3 years or less will be replaced at no cost. If it is over 3 years, then it will be replaced at a reduced cost.
SOURCE: I have an Ultra 2 bunn slush machine. One hopper
make sure it's mixed properly. if there is toomuch water, it'll freeze solid. if the mix is too rich, ice will form on the outside of the bowls. you may also have a low refrigerant level.
