HP 530 Notebook Logo
A
Anonymous Posted on Apr 13, 2013
Does the hp 530 have an internal microphone - HP 530 Notebook
How do I switch on internal microphone HP Presarion CQ57
Go to the control panel, pick the sound icon.
Check the internal microphone is shown as an option.
If so you can set to be the default.
If not you need to see it, check if it is enabled in device manager.
How do I test my internal microphone, it is not working. my laptop is compaq presario CQ 40
do you use any programs like skype / voip? Then in some case you have to configure the audio setting to work with your microphone. users manual can give you more knowledge. here is the link.
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodClassId=-1&prodTypeId=321957&prodSeriesId=3944770
My microphone not working
Dear,
Hardware troubleshooting Depending on whether you are using an internal or an external microphone, follow the steps below to see if the problem is with the hardware.Show all ' Hide allcollapse_individual_default.pngTest the internal microphoneThe internal microphone is located near the top of the notebook LCD display or near the bottom of the LCD display near the hinge. Use the following best practices to capture sound more easily.
  1. Adjust the notebook screen to place the microphone in the best direction for receiving sound.
  2. Click Start , enter sound in the search field and select Sound Recorder from the list.
  3. Click Record and speak into the microphone. Save the file to an easily-accessible location, such as the desktop.
  4. To play back the recorded sound, open the file using Windows Media Player.
  5. When using the internal microphone, choose an environment without background noise.
  6. If the recorded sound does not play back, continue to the next section of this document.
collapse_individual_default.pngTest the external microphoneVerify that the microphone port and the microphone are working properly.
  1. Test the microphone on a known, working portable tape recorder, another computer, or a device that accepts the microphone connector.
  5. If the recorded sound does not play back, continue to the next section of this document.
  6. If the microphone successfully records the voice, test the record function on the computer. If the microphone does not work properly on another computer or on a tape recorder, try using a different microphone.
collapse_individual_default.pngSet the default microphoneIf the external microphone is set as the default recording device, uninstall and reinstall the audio driver to change the default recording device to the internal microphone. The internal microphone should be the default recording device.To change the default recording device:
  1. Click Start , enter device into the search field, and then select Device Manager from the list.
  2. Expand the Sound, video and game controllers list.
  3. Right-click the audio driver , select Uninstall from the drop-down menu, and then click OK to confirm that you want to uninstall the audio driver.
  4. After the audio driver is uninstalled, click Start , enter backup into the search field, and then select HP Backup and Recovery Manager from the list.
  5. Follow the on-screen instructions to reinstall the audio driver.
The internal microphone is now set as the default recording device. Basic troubleshooting
The following are some basic troubleshooting tools that you can use to restore your microphone's functionality, depending on your operating system and/or software preferences. However, it is recommended that you first run the HP Support Assistant as it can scan your current system configuration to automatically determine if your notebook requires updated software and device drivers.
Compaq presario v3000 internal microphone not working
hi
this is gopal from hp did you see that the microphone is working or not means the hardware not the software.
1helpful
Screen does not come on
Hi, connect another screen (crt or lcd) to the video output to see if the internal circuitry works ok. If it does then your fault is either the cable to the HP screen or the circuitry inside the screen. If you have no picture on the other screen, the fault is inside the notebook.
Hp 530 booting problem
Check to make sure you have it plugged in and not working off the internal battery. Sounds like a low battery power shutdown.
Microphone for skype
Goto start-control panel-sound after that click recording tab. u can select y your microphone from there.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
