Question about Ricoh Aficio GX3050 GelSprinter
I have a RICOH GX 3050N printer it is showing a error code 990
When I did maintenance on the printer doing a head cleanging and nozzzle cleaning an error code 990 flashed in the window
  • 163 Answers
Ink collection tank full .
Posted on May 06, 2009
    Novelist:
    Habit-Forming:
  • Ricoh Expert
  • 76 Answers
  • Whenever this error code appears, this most prime thing that you need to do is to check whether all the blue toner levers are firmly pushed towards the back or not.
  • As you are done with it, check the sensor. Ensure whether it needs to be cleaned or not. You can find the sensor at the back of the plastic cover on the side of the drum.
  • Use a small and lint-free cloth to clean the plastic cover and the silver arm.
  • The sensor will be a very fine powder and should also be easy to remove.
  • Make sure that the sensor lever on TS1 is pushed up or not.
  • Clean the arm properly. Also, check whether the sensor lever is pushed up as it needs to be or not.
  • It is not set properly; the machine will not pick up the sensor on the drum. Push the disc up to make this Oki Printer Error Code 990
Posted on Jul 30, 2019
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Ricoh 3050 printer, Error 990
We got the same error on our machine, so I called Ricoh Direct Tech Support and they said it is a known manufacturer's error. All you have to do is 1. make sure your product is registered, 2. call them up and tell them the error and 3. they will send you a new machine. You will have to send back the old machine in the same box, but they provide the RMA for you to ship it back in.
Good Luck!
Posted on Jan 09, 2009
Anonymous
SOURCE: have error code 990 on ricoh gx 3000 printer how do i clear this?
you can try pulling out and reseating the Waste Ink tank which is located behind the machine behind a plastic door cover (left side of machine as you are looking at it from behind). Turn the machine off and on using the main power switch. If the code comes back then you will more than likely need a new Waste Ink Tank.
Posted on Apr 24, 2009
Derek
  • 68 Answers
SOURCE: I have a Ricoh GX 3050N printer. It says
you will have to change all the cartridges together then power cycle the printer to run initilization to reset the toner condition.
if this resolves your issue please rate my answer accordingly
regards
Posted on Sep 14, 2009
My ricoh aficio code a 990 how to fix them ?
An SC990 is usually an error indicating maintenance is overdue. The only way to verify that is by printing out the SMC report and seeing the subcodes. In the case of this model when is the last time the drum and developer was replaced?
Nov 15, 2014 | Ricoh Aficio 1015 All-In-One Laser Printer
After printer said ink cartridge was empty I removed it & found it was not-I put it back in printer & now getting error message that the cartridge is used & needs to be replaced. How can I
your only option it to replace it with a new one . printer mfg's have chipped the cartridges and they can not be reused.unless the chip is recoded as new .
Aug 16, 2017 | Ricoh Aficio GX3050N Printer
Ricoh Gx7000 inkjet A3 Printer - what does 'error 990' mean?
Error 990 indicates a dirty sensor, so either a maintenance unit is dirty or you have a clogged print head. You can read more about this error on Richo website where you can see in the images what you need to clean.
Feb 13, 2011 | Ricoh A3 Gel GX7000 InkJet Printer
Error code 990 still after reset. what to do
Error 990 is an error message that has to do with the ink drying out on the maintenance unit. Unfortunately this is a fatal error and the printer will need to be replaced as the maintenance unit can only be fixed by a technician. You will have contact Ricoh for further information on possible replacement.
Apr 09, 2010 | Ricoh Aficio GX3000 InkJet Printer
Error 990 keeps blinking on machine
This is an error that has to do with the ink drying up on the maintenance unit. This cannot be fixed by the end user and must be fixed by Ricoh. Error 990 is a Ricoh defect in which the printer should qualify for replacement.
Feb 12, 2010 | Ricoh Aficio GX5050N Printer
My Ricoh printer (Gx 3050 N)is coming up with an error message (990) and won't let me print. This started b/c it was not printing right at first (i.e. Words had white lines through them where black ink was...
Remove the ink collector from the back. If full, install new one. If it's not full check the contact (it looks like a phone jack) itmust be clean. Look inside the machine to if if the mating connector is dirty.
Jun 11, 2009 | Ricoh Aficio GX3050N Printer
Af2045 always shows sc 990
if you are getting the sc990 code, you will need to have someone come out and do preventative maintenance (PM) on the machine. the 990 code has to do with the drum quality, and the only way to fix it is to, at least, have the drum unit rebulit.
Apr 02, 2009 | Ricoh Aficio 1035 Copier
Have error code 990 on ricoh gx 3000 printer how do i clear this?
Mar 23, 2009 | Office Equipment & Supplies
Good Luck!
Dec 10, 2008 | Office Equipment & Supplies
Ricoh GX3000
ERR (990) or ERR (999) are both error messages which are displayed when a sensor does not work normally due to dirtiness. For example, either may be caused by a dirty maintenance unit or clogged ink nozzles. It may be possible to resolve the issue by cleaning the device
look here for instructions:
http://www.ricoh-usa.com/support/knowledgebase.asp?tsn=Ricoh-USA
Jan 25, 2008 | Ricoh Aficio GX3000 All-In-One Printer
Ricoh Aficio GX3050 GelSprinter Logo
2,117 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
