LG WM2487 leaked sudsy water out of a port on the back of machine, near the hot and cold water inlets. Drain hose is placed properly and drain is not clogged.
You are likely using too much detergent or the detergent is not high-efficiency detergent. Change detergents and/or lower amount and this problem should go away.
The water port on the back allows air inside the tub to escape. However, if the wrong type or quantity of detergent are used, excess suds will flow from this port.
Are you using HE detergent?
