Panasonic Lumix DMC-FZ7 Digital Camera Logo
Darryl Milstein Posted on Apr 14, 2013
Is there a long lens for the Panasonic DMC-F27?
Would like to be able to take longer distance photos with Lumix DMC-F27. What lenses are available?
Anonymous
Level 1:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Apr 18, 2013
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
127
Points
Camera is currently equipped with a Leica 12X zoom lens. I would like to be able to take pcs. from a greater distance than this lens permits. Can you recommend a lens that I can attache to the Panasonic DMC-F27 that will enable me to do so? Thank you!!
5 Related Answers
kakee
Michael Galve
  • 1269 Answers
  • Posted on Sep 16, 2008
SOURCE: The photos aren't downloading from
Make sure you have the Mac driver for your camera. Install the Mac driver that came with the CD. Try to use a different USB cable. You can also try to isolate the problem by plugging your camera to a Windows OS computer like windows xp and vista.
Anonymous
  • 155 Answers
  • Posted on Feb 09, 2009
SOURCE: I lost Panasonic LUmix DMC-TZ15 driver
Do you have a USB card reader? Just take the card from the camera, pop into the reader, and you can transfer your photos.
No drivers required unless using Windows 98 or earlier.
Also, the model is wrong, do you mean TZ5? You should be able download software for the camera from www.panasonic.com
Anonymous
  • Posted on Jan 03, 2008
SOURCE: help for Panasonic Lumix DMC-TZ 1
For a factory reset:
Turn on the camera, push the menu button, push left, down and then right.
You are now on SETUP menu.
Scroll up to the RESET option, push right and then answer YES two times.
Anonymous
  • 40 Answers
  • Posted on Feb 22, 2010
SOURCE: How can I clean the INSIDE of a Panasonic Lumix DMC-LZ7 lens?
you can clean that with paint brush..
Anonymous
  • 1705 Answers
  • Posted on May 02, 2010
SOURCE: windows 7 compatible driver for panasonic lumix camera dmc-ls70
You need to go to the lumix website and follow links to support and/or downloads for drivers.
Dmc g2 lumix message on screen lense not attached correctly
Try another lens,or set the camera to shoot without lens.This could help you narrow down if it's the lens or the camera.
Panasonic Lumix DMC TZ30 lens cover only closes half way
These things are super sensitive to ingress of dirt,i just give my lense cover a helping hans sometimes when it locks.
2helpful
Panasonic Lumix DMC-FX8 digital camera - marks on each photo
I was thinking along the lines of some kind of fungus if you were in a warm, humid climate.
2helpful
Settings for indoor jr high boys basketball lumix dmc-f27
You're probably going to get blurry photos in such a dim environment no matter what you do. There are several things you can do to minimize the blur, however.
First, if you're sitting in the bleachers, forget about using your flash. You're too far away from the action for it to make any difference.
Raise the ISO as high as you can. It will add noise to the pics, but a noisy pic is probably better than a blurry pic.
Set the camera to aperture priority, then open up the lens as far as it will go (smallest f/number). This will force the camera to use the fastest shutter speed possible.
Use the fastest lens you have (of an appropriate focal length). One of the things that separate professional sports photographers from the rest of us is the speed of their glass. They have $2000 lenses for this purpose, while we probably spend less than that on our whole kit.
3helpful
Lens won't come out after dropping camera.
Only lightly toasted. The drop likely damaged the lens tube (housing) or jarred the zoom mechanism off of its track. There is no safe DIY fix for either condition, but the camera can be repaired by the manufacturer or at a local camera shop. Make sure to get an estimate first -- you may need to decide if the camera is worth the cost of the repair.
Dust inside lense
Open the Lens Assembly and clean it but do it, in case you know how to do it.
Replacement lens cap for Panasonic Lumix DMC-FZ7 digital camera
Please see below for a link to the Lens Cap with String. This is an original part direct from Panasonic. Used specifically with this camera.
Lumix DMC-F27 Lens Cap with String
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
