HOW TO FIX WHIRLPOOL WASHER F23 ERROR CODE
What does F23 mean on whirlpool washer? It means there is a heater failure. If the water temperature in the washer fails to reach 86 degrees or higher then the washer will give the F23 error code. To fix the whirlpool
washer f23 error follow the steps listed below.
Note: Some models do not have a heater as shown below, some models just have a temperature sensor. If your model does not have a heater just skip to checking the temperature sensor.
- First unplug the washer.
- Check the wiring to the heating element make sure its not burned, broken or corroded.
- Check the heating element for continuity of course if it does not have continuity then replace the element.
- Check the water temperature sensor wiring for corrosion or breaks.
- Remove the wiring harness from the temperature sensor and measure the resistance of the sensor. Refer to the chart below and if its out of range replace the sensor.
see link below for details and where to buy the part which is under $80 and fairly easy to replace
How To Fix Whirlpool Washer F23 Error Code Appliance Repair Guides
