Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings To select a ringing tone for voice calls, select Tones > Ringing tone. To select a ringing tone for video calls, select Tones > Video call tone. To set the ringing type, select Tones > Ringing type. You can also set the device to sound a ringing tone that is a combination of the spoken name of the caller and the selected ringing tone, when someone from your contacts list calls you. Select Tones > Say caller's name. To set the volume level of the ringing tone, select Tones > Ringing volume. To set the various alert tones, select Tones > Message alert tone, E-mail alert tone, Calendar alarm tone, or Clock alarm tone. To set the device to vibrate when you receive a call, select Tones > Vibrating alert. To set the volume level of the device keypad tones, select Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
Settings In this menu, you can adjust various phone settings. To reset some menu settings to their default values, select Restore factory set. Tone settings Select Menu > Settings > Tone settings and from the available options: Ringing tone-To set the tone for incoming calls Ringing volume-To set the volume level for the ringing and message alert tones. If you set Ringing volume to be level 2 or above, your phone rings with the ringing volume ascending from level 1 to the level you have set when there is an incoming call. Vibrating alert-To set the phone to vibrate when you receive a call or a text message Message alert tone-To set the tone to sound when you receive a text message Warning tones-To set the phone to sound tones, for example, when the battery is running out of power
I had the same problem with mine. when I would go to tone settings every time I tried to hit ring tone it would turn off the phone and restart, by the way in ring tone it was blank. No matter what I did it wouldn't work. So I went to settings then restore factory settings entered the code. It reset the factory settings, then when I went back to tone settings the ring tone said Nokia Tune so I hit enter and it gave a list of all other ring tones, then it worked so my phone finally rings.... Hope it works for you.
When the ring tone cuts out, your caller goes to your voice mail, right?
The length of time before an unanswered caller goes to voice mail is called your "ring cycle" and is set by your phone carrier (e.g. Vodaphone, Verizon, Orange, etc.)
There shouldn't be any charge to change your ring cycle, and some cell carriers will let you adjust it from your account settings on their website, but the simplest answer is just to call your carrier's customer service and ask them to change the ring cycle for your number.
For cell carriers in the US, you can call 611 from your phone to reach your carrier's customer service, but I don't know about other countries' mobile carriers.
Not too sure about the no dial tone issue, but you can check to see if the DND is turned on...
Press the Blue Superkey and scroll thru till you see DND (Do Not Disturb) is on and shut it off.
Try this.
Go to PROFILES.
Select ADVANCED.
Select (ie) NORMAL.
Scroll to SMS TEXT and depress the pearl ball.
Select OUT OF HOLSTER and set to TONE.
Select RING TONE and select the tone you want.
Select VOLUME and set to your preference.
You might want to do the same for IN HOLSTER. Good Luck! ~ :)
If you set the profile ring tone to OFF. Then select a contacts' number and assign it a Ring Tone. When that contact calls you the Ring Tone you assigned will ring.
If you select the same Ring Tone for all your contacts in a group they will all sound the same when they call.
Or select the same ring tone for a profile, but cancel the Tone you assigned to the contact(s).
