I've been trying to add and delete music from my ipod touch and can't figure out how? please help me!
Bearshare is a program that can be used to download and listen to audio files on your computer. You can also use Bearshare to put music directly onto your iPod or portable music player. Using Bearshare to add songs to your iPod will save you the time of having to search for your downloaded files using iTunes. By using Bearshare, you can download a new song and place that song directly onto your iPod without having to open another software program.
Download the latest version of Bearshare (see Below). http://www.bearshare.com/ Install Bearshare onto your computer. When you do, Bearshare will search for audio files that are already on your computer. The program will then add those files to the "My Library" portion of Bearshare. Open Bearshare. Click the "iPod/Mp3 Player" option on the left side of Bearshare. Plug your iPod into your computer. A dialog box will open on your screen. Click "OK." The "iPod/Mp3 Player" option will be replaced with the name of your iPod. Click the "My Library" option in the top left corner of Bearshare. Any songs that you added when installing Bearshare or that you have downloaded with Bearshare will appear on the screen. Click on the song and then drag the file over to the name of your iPod found on the left side of the screen. Doing so will add that song to your iPod. Continue doing this until you are finished adding songs to your iPod. Disconnect the iPod and close Bearshare.
SOURCE: changing music on ipod
connect it up to the pc,wait till its recognised,go to my computer,open it and look for a drive g,right click on it and then format,this will get rid of the music and anything else you have on there and you can then add new,or the alturnative is to go to driver g,explore it and delete music files manually.if not clued up on it the easiest way is to format.ok
SOURCE: delete songs from my music file from my computor
Below is a URL that you can copy and paste into your browser bar. It will take you directly to the iPod manual that will teach you every thing you need to know about syncing and deleting content on the iPod. :)
http://manuals.info.apple.com/en_US/iPod_nano_4th_gen_UserGuide.pdf
SOURCE: How do I add music files to my Thomson Lyra jukebox PDP2860
The best way would be to use the software that comes with the Lyra but if you dont have/use it then you simply drag and drop the files as you do with the films.
The difference being that you must manually 'Profile Contents' which is in the 'Audio' menu, if you use the drag and drop method whereas the software does this automatically.
Your files will magically appear when you have done this.
SOURCE: Can't unlock my iPod Touch!!!!
u r screwed up. get help from mac people.they have utility to bust it
SOURCE: I've downloaded between 30 and
Hi rodglo2..
Try this method to delete what you do not want..
Deleting Files,Pictures,Videos,Audio Books, Apps,etc. from MP3 Player/Ipod
BIG WARNING: DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
ONE MORE BIG WARNING: BE CAREFUL AND DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Please take time to rate me
