I heard a pop sound- like a light bulb hitting the floor. I turned on the tv and got only sound, no picture. whats wrong
SOURCE: Red light came on tv , replaced lamp and still no picture
Look at it really carefully where the bulb plugs into the lame the connector is not sitting firmly on it reconnect it and make sure it's firmly connected to the plug.
SOURCE: tv turns on and than red status light comes on and shuts down
it sounds like the 3300uf caps on the power supply have gone bad.look at them and see if they are pregnant. if so change them. while you have the shield off see if any other caps are pregnant, if so you might want to think about having the chassis repaired.
SOURCE: status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
SOURCE: wd-52725 had blue screen no picture or sound
you may be on the incorrect input channel. look for an input or tv video button and choose each input until u get a picture
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
